TwinTurbo.NET: Nissan 300ZX forum - Re: I'm stuck. Please help. How do I get the first set of
Goldchocobo
on March 16, 2015 at 11:46 AM
posted by Zuberman
on March 16, 2015 at 11:13 AM
It's extremely easy. A ratchet, an extension, and the appropriate socket. I believe it's 17mm. Prepare to hate your life if you break the studs, which is entirely possible. I broke half of my studs, and ended up using C-clamps to re-attach the cats.
Zuberman
11:13:19 03/16/15
Re: I'm stuck. Please help. How do I get the first set of -
Goldchocobo
11:46:06 03/16/15
Do you go after it from underneath the car or from above
Zuberman
12:29:57 03/16/15
Underneath
Goldchocobo
12:52:13 03/16/15
Do you mean precats, AKA downpipes?
Goldchocobo
13:55:48 03/16/15
Engine, Turbos, catalytic-converters: those ones. The ones
Zuberman
15:21:27 03/16/15
Re: Engine, Turbos, catalytic-converters: those ones. The ones
ttz'in (norcal)
15:54:40 03/16/15
Part# 14440 and 14440+A (n/m)
Zuberman
16:38:48 03/16/15
Yes sir,..Think Z1 still offers a buy back program. (n/m)
ttz'in (norcal)
16:45:51 03/16/15
I think we missed each other somewhere, but I may just offer
Zuberman
17:01:08 03/16/15
Re: I think we missed each other somewhere, but I may just offer
ttz'in (norcal)
17:06:23 03/16/15
If you mean the pre-cats, it's not impossible, just
ttz'in (norcal)
13:16:12 03/16/15
Does removing the aluminum heat shields from the cats give
Zuberman
16:59:06 03/16/15
Re: Does removing the aluminum heat shields from the cats give
ttz'in (norcal)
17:04:00 03/16/15
I mean if I remove the aluminum heat shields from the pre-
Zuberman
21:54:43 03/16/15
Re: I mean if I remove the aluminum heat shields from the pre-
ttz'in (norcal)
22:17:36 03/16/15
Yes, I always pull the heat shields
BlackholeZ
22:25:39 03/16/15
^ Agree ^ (n/m)
ttz'in (norcal)
22:29:51 03/16/15
It's a pain
BlackholeZ
22:21:59 03/16/15
I do have my plenum off as well as my valve covers.
Zuberman
22:37:28 03/16/15
Well if you have the plenum off that helps a lot
BlackholeZ
22:52:37 03/16/15
VIDEO, driver-side: I see one pre-cat bolt on top that I
Zuberman
23:44:51 03/16/15
Removing precats with tranny still in...
240Z FeO2
00:54:44 03/17/15
The 4th is inboard (towards the motor)
BlackholeZ
01:19:31 03/17/15
Not sure if anyone is interested but the pre-cats are off.
Zuberman
21:19:14 03/19/15
